COM port not detected in exe
In my development vi COM port are visible in the drop down, whereas when exe is created, COM ports are not visible. I have labview 2019 and installed NI VISA 19.5, NI Serial 2019 and NI VISA run time 2019. I have attached the sample project for your reference.
Fig1. Labview Vi where com port are detected.
Fig 2. EXE where com port is not detected.
Fig 3. NI MAX software list
Message 1 of 20
(2,976 Views)
Can anyone help regarding this issue.
Message 2 of 20
(2,929 Views)
Try something like this:
=== Engineer Ambiguously ===
Message 3 of 20
(2,907 Views)
Hi RTSLVU,
Your snippet is LV2023, while I am using LV2019. I have tried to replicate your VI and here are the results.
I tried your VI, in development mode COM ports are detected in array.
Fig1. LabVIEW VI
Whereas, when exe is created and executed the array of string is empty.
Fig 2. In exe mode the array is empty.
Message 4 of 20
(2,866 Views)
The problem is in first block itself, In VI I get the list of resources.
Fig 1. VI mode.
Whereas in exe mode the find instrument is empty.
Fig 2. Exe
Message 5 of 20
(2,862 Views)
I tried with the following expression which was mentioned in the help, and it is working in exe as well, I'm using 2021 64 bit.
"ASRL[0-9]*::?*INSTR'
bp
Message 6 of 20
(2,852 Views)
Silly question,
Is the Exe used on the same computer as the development VI?
Message 7 of 20
(2,846 Views)
Yes, exe and development vi is in same pc.
Message 8 of 20
(2,839 Views)
This is nearly unexplainable. What if you uncheck "Allow future versions of the LabVIEW Runtime etc..." in the program build specifications? (Just a shot in the dark).
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 9 of 20
(2,834 Views)
I have unchecked " Allow future version..." but still facing same issue in exe.
Message 10 of 20
(2,826 Views)
