COM port problem
Hi Gents,
Sorry a really newbie question but i cannot get the VISA serialport to work. Smiley Sad
When i use Hyperterminal and other sw i can read from the COM4 without any problems. I.e. the hardware works.
But when i run the "Basic Serial Read and Write.vi" i get a strange "-1073807202" error message?
I get the same message when i dive into the "VISA Configure Serial Port (Instr).vi" trying several COM ports etc.
Any hints?
Btw im running Labview 8.2 on a Vista machine.
Thanks!
Message 1 of 9
(4,805 Views)
That usually means you don't have VISA installed. Launch MAX (Measurement and Automation Explorer and expand the tree item My System->Software. Verify that NI-VISA is there. If you don't have MAX or NI-VISA, rerun the installer and install VISA.
Message 2 of 9
(4,802 Views)
Izze2000 ,
   For this problem problem as the above reply states visa is not installed, what you can do to rectify this error is installing the driver CDs to get the NI VISA.
Sivakumar G
Message 3 of 9
(4,789 Views)
Message 4 of 9
(4,761 Views)
What are you using as your VISA resource name? It should be in the form ASRL[board][::INSTR] (note that the characters [ and ] are placeholders). In your case it would be ASRL4::INSTR.
Message 5 of 9
(4,755 Views)
Ok!
I have tried both COM4 and now ASRL4::INSTR as you mentioned, thanks.
I also probed the VISA recource name in the Diagram view where COM4 alt. ASRL4::INSTR shows up in the "VISA refnum"
still no cigarr Smiley Sad
Also when i do a refresh in the Visa recource name no COM ports shows up?
Message 6 of 9
(4,752 Views)
Before you even think of using LabVIEW, make sure that the com port is being shown in MAX. Expand the Devices and Interfaces>Serial and Parallel and see if the port is listed there. LabVIEW will get the resources from what MAX finds.
Message 7 of 9
(4,747 Views)
...i checked MAX as you said. The COM ports are there, seems to be ok.
Now when i got back to Labvie the vi suddely works Smiley Very Happy
Q: did the port checking in the MAX initiate the ports or, just curios?
Anyway, thanks alot guys guys!!.....now i  need to start to do some programming Smiley Happy
Message 8 of 9
(4,741 Views)
Going into MAX forced it to do a refresh and to check for new resources. Glad it's working now.
Message 9 of 9
(4,734 Views)
