COMUNICATION VIA MODBUS TCP
(3,339 Views)
 Hello
I want to ask if there is some sample code for establishing communication with modbus modbud ttsp library
(3,337 Views)
please try these links:-
http://forums.ni.com/t5/LabVIEW/Modbus-TCP/m-p/1134456
http://forums.ni.com/t5/LabVIEW/ModBus-TCP-communication-dropouts-on-Watlow-gateway/m-p/1056299
http://forums.ni.com/t5/LabVIEW/Problem-communicating-via-Modbus-TCP-with-Honeywell-UDC3200/m-p/7530...
http://forums.ni.com/t5/LabVIEW/modbus-communication-problem/m-p/1137313
Hope these helps.
Thanks as kudos only:)
(3,332 Views)
Hello.
I suggest you to start with examples that comes with library when you install it. Those examples should be usefull and simple enough in order to start to work with Modbus TCP.
Kind regrads,
Sofija
(3,297 Views)
