CONFIGURING DIGITAL I/O IN LABVIEW USING PCI-6071E
Iam using NI PCI-6071E DAQ board for data acquisition.Iam able to read analog inputss,by using datalogger iam able to see the measurement as -5 volts.But the problem is iam not able to read Digital i/os.I would like to know how it will display in datalogger,I mean, wether it will show 1 and 0 or some thing els.I tested with example VIs,in this examples the LEDs are glowing green after i run the VI,but after deleting the channels from the MAX still the VI is showing green LEDS when i run the VI.
(2,677 Views)
you will find a example in LabVIEW example finder.
Go to the tab "search" keyword is datalogger
Than use the Digital data logger.vi
Hope this Helps
Best Regards
SebastianN
(2,677 Views)
Thank you very much for your reply.Iam able to read the digital i/o as 1s or 0s but i want to display these binary valus in tabular form.How can i do?
any examples are welcome
(2,677 Views)
