CONVERSION OF 1D ARRAY TO 1D ARRAY OF CLUSTER
Metachnet wrote:
I have tryed make a 16 channel chart but was unscucessful, when I wired a 16 plot array of dbl I still was able to make only one plot chart.
Then show us that code. Obviously you are doing something wrong.
Message 11 of 15
(1,127 Views)
Still same code
Message 12 of 15
(1,120 Views)
Use Build Array instead of the Array To Cluster
Message 13 of 15
(1,115 Views)
Thank you for your example.
I tried to implement your concept.
To charts that read data from same array.
First array number is for chart 1 plot 0:
2nd array numberr is for chart 2 plot 1.
So each chart displays only its plot.
Please tell me if I am doing it correct. thnks.
Message 14 of 15
(1,102 Views)
Accepted by topic author Metachnet
Why are you making things so difficult?  Just index the array.  But why can't they just be in the same chart?
Message 15 of 15
(1,095 Views)
