CPU USAGE MAXED OUT
I am writing analog input values to a cluster every 60 seconds. every time i run this vi my CPU Usage jumps up to 100%. Can someone take a look at my code and see if there is something basic that i am doing wrong. ANy help is Greatly Appreciated.
(2,996 Views)
Can you please attach the missing subvi "analog new3.vi"
(2,991 Views)
Here it is. Thanks
(2,980 Views)
Because you are starting and stoping 100 Daq tasks (8x12) your Pc gets very busy I guess. Try to read multiple channels at once. If all your channels should be configurable you can build a daq task in LV.
(2,966 Views)
