CPU Usage property in System Configuration prompts an error, Property is not available for the selected resource.
I'm trying to monitor CPU Load using system Configuration tools. I've two computers, this code works well on one PC but the other one generates error.
(2,633 Views)
What versions of the operating systems are running on both? What is the model and type for each computer. Could be that you need to update something on the computer that is failing. Perhaps a bios update.
Tim
GHSP
(2,621 Views)
Hi, Thanks for replying.
I'm using windows 7 Pro on both system. Having same version of LabView, i.e LabView 2019.
Systems are NI PXIe-8880. The system in which I'm facing the issue doesn't shows cores information in NI Max.
I am sharing NI Max snapshot for both PC's.
(2,587 Views)
