CPU load goes to 100% with IMAQ interface and 4 serial ports. Any trick?
Hello to all,
I am using an IMAQ interface in conjunction with 4 serial ports for data acquisition. Both systems run with different VI's. My problem comes when I run both at the same time. In this case the CPU goes to 100%, and both programs slow down drastically. I must keep a sample rate between 300 and 600 ms for the test (easily achieved by the IMAQ or when I run only the VI for the serial ports), but unfortunately the sample rate goes to 3-4 seconds when running both programs at the same time.
I have put “Wait (ms)” in every single while loop, but the delay stays and the CPU is still on the 100%.
Do you have any clue to overcome this? Any help will be greatly appreciated.
Thanks in advance.
Alejo.
(2,680 Views)
Post your code so we can look at it.
You should be able to achieve your goals with the hardware.
Greg Bush CLAD
(2,674 Views)
Thanks for your reply bushman. I will post the files tomorrow morning at work.
(2,665 Views)
Ok, this is my VI for the data aquisition through the 4 serial ports. The block diagram of the IMAQ sofware is password protected and I cannot send it at this time. I hope the problem is in the first one.
Again, thanks.
Alejo.
(2,652 Views)
