CPU performance monitor?
@Andrey_Dmitriev wrote:
works like charm in LabVIew 2020 64bit on Windows 11
on a side note: you can use a stacked, not transposed waveform chart to compare the cpu % for each core.
Spoiler
Message 11 of 17
(1,342 Views)
With the fix you've posted it works fine on my PC and I started to have the feeling that this solution is equivalent with the one I linked when I created this topic. (its just calling the dll directly not thru the .net nodes)
I'm not sure if its just me but the numbers dont really add up. For me the total CPU usage (displayed in the task manager) should be: sum(proc% for each cores) / number of cores, but the number I get is significantly different than what I see in the task manager.
Message 12 of 17
(1,331 Views)
If you would like to get overall utilization, then you should use \Processor(_Total)\% Processor Time performance counter, (of course, you can combine multiple counters if needed) something like that:
hope it helps,
Andrey.
Message 13 of 17
(1,324 Views)
processor>% processor time includes a built in _Total that you can use for reference
turns out, this built-in total  is quite the same as a total from the formula = sum(proc% for each cores) / number of cores
Spoiler
I use the chart in https://forums.ni.com/t5/Example-Code/Performance-Monitor-Using-LabVIEW/ta-p/3501988 to log all processor time values
I used 7-Zip Benchmark to create a reproducable load, which is depicted in my chart and graphs
Then, I just copy and past the Chart to a new .vi and look at the Chart History (default length: 1024)
Message 14 of 17
(1,268 Views)
Spoiler
Why need 7-zip and do not use such a great tool called LabVIEW?
Timed Loops can be assigned to physical CPUs, and at works (well, a little bit tricky if hyperthreading is enabled, but anyway). Another possibility is to use CPUStress from SysInternals, where you can assign affinity mask to individual cores: https://learn.microsoft.com/en-us/sysinternals/downloads/cpustres
Message 15 of 17
(1,245 Views)
I probably got lazy 😉
Message 16 of 17
(1,207 Views)
Yeah, I've found the _total is practically the same as the formula I used to get the total load on my own.
Message 17 of 17
(1,203 Views)
