CPU runs 100% when logging with DAQmx using card 6229
Hi!
When I start a logging using DAQmx Analog Input  the computer CPU runs 100%. This causes the problem that the computer locks and the subsequent steps in the program are left without computer CPU recourse. After the logging is compleet, 1750 samples/10 channels at 250Hz, the program runs on, but the loggfile is at that point useles.
I have instaled LV 7.1.1 and am using DAQ 7.4.
Anyone that recognizes this problem?
Idriz
Idriz "Minnet" Zogaj, M.Sc. Engineering Physics
Memory Profesional
direct: +46 (0) - 734 32 00 10
http://www.zogaj.se
(3,035 Views)
hi there,
are you really sure you're using DAQmx 7.4? i ask because 7.3 had some reasonable problems with CPU usage. see the software section in MAX to get the version number. to be sure i suggest to download DAQmx 7.5 and reinstall it over LabVIEW 7.1.1.
have you tried to run some of the examples shipped with LabVIEW? if they also don't work i suggest to post some code so we can have a look.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,016 Views)
Hello Idriz!
I just wanted to respond here as well so you know that we have read your post on this very forum. Still waiting for an answer from the US and after that I will forward that information to you.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,006 Views)
Hello!
I sent you the example through e-mail but it might be interesting for others as well to see how you can handle CPU usage and DAQmx.
Jimmie A.
Jimmie Adolph
(2,917 Views)
