CR character in String control
Hello there,
I'm trying to create a VI that recognizes Carriage Return character (ASCII code 13) entered to a String control.
I use Match Pattern function and tried some different constants as a pattern: \r, CR constant, LF constant.  Nothing works.
Could anybody help me with this to be easy task?
Greg
Message 1 of 14
(6,680 Views)
Works here just fine. Use a "\r" as pattern (normal display for the string constant!).
If this does not work, maybe you can make a small example that shows the problem.
Are you sure your string contains a \r? Set it to '\codes' display to be sure.
Message 2 of 14
(6,677 Views)
<< Are you sure your string contains a \r? >>
I type some characters into a String control and hit "Enter" key.  I want to catch this character and perform some actions on this event.
Please see attached VI written in LabView 7.0
Greg
Message 3 of 14
(6,657 Views)
Hey Greg:
Had a quick look at your code ... remove the quotes from the constant and change the string control to "\" codes display.  Enter \r into the control and everything works the way it should.  Don't need the quotes.  Good Luck.
Greycat
Message 4 of 14
(6,651 Views)
You have your string control set to "limit to single line". This means that [enter] terminates the input and is not added to the text string.
Also: LabVIEW generates a newline (\n) when you press enter on a string that allows multiple lines. (\r) never happens!
Also: remove the quotes from the pattern input. THe pattern should be a plain two-character string: \n
Also: If you want to check the input while typing (and it seems you want to), you need to set the control to "update while typing".
See if you can now figure it out. Good luck! 🙂
Message 5 of 14
(6,645 Views)
Thanks guys,
Greycat wasn't exactly right. Recommendations of Altenbach helped me.
It's good to know that LabView doesn't generate CR character.  So, if I want to send that string to a COM port I have to append CR.  I came to LabView from "traditional" programming and this fact seems a bit strange to me.
If interested, see final working version.
Greg
Message 6 of 14
(6,634 Views)
Well, all these wires and loops seem somewhat silly because what you really want seems to be already offered by the "limit to single line" option. I would suggest:
  1. Set the string control to "limit to single line"
  2. Disable "update value while typing" so the code waits until [enter] is pressed.
  3. Use an event structure for "value change", it will be trigered once you hit [enter].
  4. Append \r to the string before sending it to the serial port.
Attached picture shows a "semi-equivalent" code construct. It might just do what you need without polling. Of course real code should do some syntax checking on the string and loop over the event structure until things are OK. Modify as needed.
Message Edited by altenbach on 04-26-2007 12:23 PM
Message 7 of 14
(6,626 Views)
Hi Greg, altenbach:
Yes, I wasn't exactly right ... I read the posts too quickly ... I now see what you were after ... sorry for not taking the time I should have before answeringSmiley Tongue .. Glad you are on your way to getting it to work.
Greycat
Message 8 of 14
(6,619 Views)
Why when I press enter it dosen´t work? I mean de NS that I introduce disappears when I press enter
Message 9 of 14
(5,372 Views)
Attach a VI rather than a picture.  That way we can see the things that can't be seen in a picture.
My guess is.
1.  Your \n is still not showing in \codes mode.
2.  Your NS control is still set for multiple lines, thus when you hit enter it appears to disappear.
Message 10 of 14
(5,365 Views)
