CRC-16 CCITT Calculation
Turn it into a subVI and call it.  Pass in whatever data you need to into it.  It is just like reusing any other piece of code.
GCentral
Message 21 of 30
(5,860 Views)
Old thread, I know, but I'm looking at a similar problem...I need to turn the C routine below into a subvi. I've tried many different variations of many different solutions and cannot get the CRC shown in below to match. Does this make any sense to anyone here?
CRC is a 16-bit CRC of sync, address, command type, length, and data fields. The algorithm used is CCITT-16 (0x1021 or 0x8408 reversed).The remainder is initialized to all 1’s (0xFFFF) and the CRC is inverted before being sent, LSB first.  (NOTE: Previous versions of this document specified MSB first, but actual implementations have been using LSB-first.)  Following is a sample C routine which implements the algorithm using the “reversed” technique:
WORD crc16_lsb(BYTE *pData, WORD length)
   BYTE i;
   WORD data, crc;
   crc = 0xFFFF;
   if (length == 0)
      return 0;
   do
      data = (WORD)0x00FF & *pData++;
      crc = crc ^ data;
      for (i = 8; i > 0; i--)
         if (crc & 0x0001)
            crc = (crc >> 1) ^ 0x8408;
         else
            crc >>= 1;
   while (--length);
   crc = ~crc;
   return (crc);
For example, a Status Request command:
      1b ff 91 00
Would generate the following CRC:
      1c 39
Message 22 of 30
(5,417 Views)
Accepted by wiebe@CARYA
With the right parameters, this works perfectly with my standard CRC calculator.
GCentral
Message 23 of 30
(5,392 Views)
Thanks, crossrulz. You're right, it works exactly as it should. You da man!
Message 24 of 30
(5,381 Views)
I noticed that the marked solution is not the correct one, at least for me. If it is so for others as well, could someone please mark the correct reply as the solution? It is a bit misleading as it is.
So the correct one according to my tests iiis:
https://forums.ni.com/t5/LabVIEW/CRC-16-CCITT-Calculation/m-p/3224707/highlight/true#M937083
Message 25 of 30
(4,254 Views)
I did mark that one as 2nd solutions. I can't unmark the other one. Not sure if a moderator can do that, or if only OP has the power to do that...
Not that helpful as it is, as there's no "go to next solution" button...
Message 26 of 30
(4,247 Views)
That is part of the problem with people resurrecting old threads.  The post that was originally marked as the solution was the solution for the OP.  Somebody later resurrected the thread with a different problem.
GCentral
Message 27 of 30
(4,235 Views)
I figured that was going on here (TL;DR).
Anyway, you have an extra solution, and I can't unmark it as solution anyway!
Message 28 of 30
(4,231 Views)
I see your point. Anyway, the "good" one is aslo marked, I hope it helps people like me.
Message 29 of 30
(4,225 Views)
I ran into this same problem several years ago. I am not a C programmer whereas I was given the C code that generated the CRC. I had a C program explain in detail what the C code was doing and I created a LabVIEW vi that worked. Once you understand what is being done in the C code, you will be able to reproduce the algorithm in LabVIEW.
Message 30 of 30
(3,734 Views)
