CRC-16-DNP Calculation Trouble
Having trouble implementing a Labview version of a CRC calculation performed in our FW. This is for a 16 bit DNP protocol. I have implemented a very simple VI that I believe is true to the code implementation, but I am not coming up with the same results.
Test message is
05 64 0b c4 01 00 40 00
with a proper CRC of
A72E
I however get a CRC calculation of D158. Not sure where I have gone wrong. Any help would be greatly appreciated.
Matt Kraus
(5,763 Views)
My only guess at the moment is that you make a mistake in the table.  I just do not have the time to check all 256 elements.
(5,725 Views)
Accepted by topic author 14gipper
Looks like you might have missed one last step from the calculation. After googling CRC-DNP, the final step is to take the complement and swapping bytes to get the final answer.
Feel free. Contact me for anything more,
    Pang
You too can be LabVIEW Awesome!
(5,695 Views)
@pangvady wrote:
Rube!  There is a primitive called Swap Bytes that you can use instead of the Separate Numbers and Join Numbers.
(5,686 Views)
That did it. Thanks for the catch. Banged my head against the monitor all day over that.
Matt Kraus
(5,654 Views)
Finished VI attached for the next lost soul searching for DNP CRC.
Matt Kraus
(5,649 Views)
