CRC 16 on FIFO data
Hi all,
I'm having some difficulty adapting some code to generate a particular 16 bit crc. I have an expected result of: x0CA6 for a sample set of 32bit data (32 bit data x 64 to be precise). The datasheet specifies that the CRC should be initialized to 0xFFFF
I'm using some code that i found on here that takes a byte array as it's input and calculates a 16 crc.
The polynomial is 0xD175.
I'd appreciate any help!
Datasheet SpecDatasheet SpecBlock diagramBlock diagram
FIFO 64 samples + CRC (sample 65)FIFO 64 samples + CRC (sample 65) CRC output resultCRC output result
Message 1 of 1
(2,261 Views)
