CRC-16 with 0x8005 polynomial
I am using a CRC-16 VI from an NI community page that uses 0xA001, which is the reverse of the polynomial I want to use, 0x8005. For example, with one byte data 0xD6, the CRC-16 with 0xA001 is 0xDE3E, it should be 0x9E81 using polynomial 0x8005. Simply changing the polynomial does not seem to give the right result. I have an image attached. Is there something I should "flip", or "reverse" to in order to use the polynomial I want and get the right answer?
Message 1 of 22
(12,157 Views)
Unfortunately, there are many ways to do a CRC.  Where are you getting the data point for your example?  Does that source have some source code (usually in C) we can look at?
Message 2 of 22
(12,144 Views)
The data is entered in the front panel. This VI can be used as a sub-VI for other VIs. There is no C-code, just the VI.
Message 3 of 22
(12,103 Views)
The input control is an array of U8.
If your data source is little endian, then the bytes might need to be swapped after converting the array to unsigned word integer. LabVIEW is big endian.
http://zone.ni.com/reference/en-XX/help/371361H-01/glang/swap_bytes/
Message 4 of 22
(12,085 Views)
What I was asking is where your "0x9E81" came from.
Message 5 of 22
(12,070 Views)
I used an online CRC-16 site to check the output of the VI against. This one:
http://www.lammertbies.nl/comm/info/crc-calculation.html
Message 6 of 22
(12,064 Views)
After downloading the library from that site, I see that the CRC-16 with a 0x8005 is doing things a little differently than a "normal" CRC.  I'll see if I can get some time at lunch to mess around with it.
Message 7 of 22
(12,053 Views)
I am not using the library from that site. I was using the site's online CRC calculation to check the output of the VI above against the site's normal CRC-16. In the end, I need the VI above to compute CRC-16 with polynomial 0x8005...
Message 8 of 22
(12,048 Views)
I get the 0x9e81 result using a 0x8005 polynomial with the following: "Reverse Data Bits" Use rotate right with carry which you do correctly. Use an "Initial Value" of 0x0000 not 0xFFFF. Finally do a "Bit Reversal" of the CRC.
Message 9 of 22
(12,033 Views)
I did not think about reversing the bits in the final CRC.  It is kind of a pain, but it did work.
Message 10 of 22
(12,017 Views)
