CRC
Hi
Has anybody created a 16 bit CRC sub-vi in labview. If so, is it
possible to look at some sample code
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,791 Views)
In our vi-library (on-line: www.air.nl), there is a U8 CRC vi. Look in the
ModBus code. Input of the vi is an U8-array, output is a U16. Maybe it will
help.
You can find documentation on CRC's in Numerical Recipes, chapter 20-3 :
http://www.ulib.org/webRoot/Books/Numerical_Recipes/bookcpdf.html
Wiebe Walstra
AIR technical Automation
www.air.nl
wrote in message news:8uv7b2$3qk$1@nnrp1.deja.com...
Hi
Before you buy.
(3,791 Views)
I see no such VI at the posted location.
(3,791 Views)
Hope this helps...
Martin
> Hi
> Thanks
> Before you buy.
[Attachment CRC16_example.llb, see below]
(3,791 Views)
This code doesn't appear to function.
(3,791 Views)
