CRC16-CCITT verification VI
Hello!
I am working in a project that uses CRC16 to evaluate transmission errors between an emitter and a receiver. Data is transmitted via RF.
In the emitter side, I already have an algorithm to generate CRC16. Then, data is sent in a string with the correspondent CRA.
For example, let’s consider the string “123456789”. The CRC for this string is 31C3 (hexadecimal). So, the message sent will be “12345678931C3”.
Now this message will be received in a VI that I want to create, via Serial Port (using VISA Read). Then I must process the CRC verification dividing the received message by the CRC16 polynomial (1021 hexadecimal) to see if the remainder is zero. If so, the message has no errors.
I think that I should provide a XOR operation between the received string and the polynomial for sometimes until no further division is possible.
Can anyone help me with this? I just need the CRC verification part, since the string processing I know what to do and how to do.
Thank you very much.
Duarte
(5,585 Views)
Accepted by topic author DuarteCota
Here's a link to LabVIEW CRC stuff.  This should save you a lot of heartache.  😉
http://forums.ni.com/t5/Example-Program-Drafts/Inline-CRC-Reference-Library-CRC-32-CRC-16-and-CRC-8/...
Bill
CLD
(Mid-Level minion.)
(5,578 Views)
I typically just perform the same CRC algorithm on the data and just check to see if it matches the supplied CRC.  Not all CRCs will go back to 0 when performed with the calculated CRC.
GCentral
(5,573 Views)
Thank you very much!
(5,538 Views)
Thanks are given with kudos and marking solutions.
(5,509 Views)
Hooovahh escreveu:
Not only. 🙂
Done!
Thanks for reminding.
(5,491 Views)
