CRIO RT position control for user file
Hello Everyone
I've created a PID controlled hydraulic application and I controlled the position  by using Sine generator with the help of
CRIO 9074 and NI 9263.I worked the code on Realtime side. My freq is about between 0.67 to 1.5Hz. I used Fs=1000 s=1000 for
1hz. It works very well.  But now I have a new problem I have to solve. I have calculated the position of cylinder in 1ms time resulation (or
2ms-3ms).How can I apply the position of cylinder with the help of excel file or any other file format(If I learn
the way of control. I can get the position from excel) . How can I use the data below as a position signal for PID.
for example
(1HZ-10MM)
1ms  0,1mm
2ms  0,4mm
3ms  0,87mm
1000ms 10mm
(3,329 Views)
Hi Sea,
convert your Excel file to CSV format. Transfer the CSV file to your cRIO and load it there using ReadFromSpreadsheetFile...
(3,292 Views)
Hi ,
Thank you for your idea. But I m looking for answer the position control with the help of PID controller. I did position control with sinus generator as my set point data. But now I want to use  user defined position data as set point data instead of sinus generator.
(3,278 Views)
Hi Sea1
I am not sure that I understand your issue or question; if you have a list of values in Excel with the parameters that you want to use for you PID then as GerdW recommended you can create and read the file to find a reference or pointer to select the parameters you want to use.
But if the excel data has some sort of parameter instead of reading a file it might be easier to calculate the values.
Could you provide us with more information or a more detailed explanation of what you want to do?
Regards
Esteban R.
(3,270 Views)
