CSV database
I  built a huge VI to monitor a person details.
i wanted to modify this VI to be for several people.
i don't have any access to any of SQL or SQL Server Express, neither MS Access to build a database.
my only option is using CSV file as a database.
writing to a CSV file is not a problem to me.
reading the details is my problem.
in the VI i have a user ID, age, weight, gender,  etc..... if i want to retrieve a data for one specific user, i should look into his ID. when i find this user, i should retrieve all the data that belongs to this ID.
is there any link or a demo can let me learn this technique. i know i should user Search 1D array to look for the user ID, but up to the minute i don't know how to make it in the right way.
any suggesting ?
Message 1 of 9
(5,971 Views)
Read the file with Read from spreadsheet file, Index array to get the ID column, Search 1D array to find which row and Index array to get the user row.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(5,962 Views)
i tried this way, and i'm still not able to make it.
Message 3 of 9
(5,934 Views)
Hi N.,
attach your try (aka your current VI) and a sample CSV file to allow us to help you…
Message 4 of 9
(5,931 Views)
Hi GerdW,
this is a mock up of what i'm doing exactly in my VI.
and i know i'm doing it wrong, but i never used Search 1D array before
Message 5 of 9
(5,923 Views)
Hi N.,
what exactly does not work as intended?
In your VI you are
- reading a CSV file with each iteration, getting the first column and searching for something in this (column) array
- not using the search result
- appending the the very same CSV file a new line of user information
- doing all that in a loop again and again, without any timing (your file will get very big very fast)
Message 6 of 9
(5,909 Views)
the first and second point i didn't get them very well.
i wanted to append the file
and in my actual VI i'm using QMH, so i'm writing only once when i needed
Message 7 of 9
(5,902 Views)
Hi N.,
You are reading the CSV file, index the first column and search for an element of this column.
What didn't you "get very well"?
Message 8 of 9
(5,900 Views)
Well, you could try SQLite and theSQLite Library for LabVIEW by Dr. James Powell.
https://www.ni.com/en/support/downloads/tools-network/download.sqlite-library.html
Free, easy to work with, good examples and documentation and far superior to CSV.
Message 9 of 9
(5,877 Views)
