CSV file to image file
I am using CSV file format in which lat/long, locations and various parameters are listed. I want to use this file to build an image??
The other option using this file for plotting the values on a graph??
(2,504 Views)
Seems pretty trivial. So what kind of problems did you encounter?
What is your question?
Show us a typical csv file and show us what you are doing and what the output should look like. THme maybe we can help. 😄
(2,499 Views)
