CTRL-Z undo in Built Applications.
Make Undo availible in built applications ( Exe's ).
Using CTRL-Z does not work in Exe's.
The only way to "work arround this is".
1) When builidng your VI you have to disable the menubar. ( but most mature apps need a menubar ).
2) You can flicker the menu bars programatically, see the opening post for more detail
http://forums.ni.com/t5/LabVIEW/Using-UNDO-ctrl-z-in-Built-applications/m-p/1318179#M539810
but this is not a good solution as you need to press CTRL-Z 2x, and if a user uses the mouse only ... the undo won't work.
A third thig is that the CTRL-Z functionality has unfortunately been unavailible for Graphs in 2010. Previously in 2009 you were able to do the CTRL-Z on a graph at it woud for exampe return to you previous scale settings.
Now the shortut does not have an effect.
Maciej
(5,782 Views)
This has been reported as a bug to our R&D department under CAR# 276280.  The CAR includes the change in the CTRL-Z functionality from 2009 to 2010, as well having to disable the menu bar.  Thank you very much for making this issue known to us.
Brandon Treece
(5,691 Views)
