CURSOR WEIRD BEHAVIOR
i have created an anotation linst subvia which gets me out 1d array of 4 elements each representing a cursor to be seen on an xy graph at a later stage on the program.
now on the stage where the xy graph becomes visible, the 4 cursors appear in it, but the cursor legen is blank.
now if i double click on the cursor legent and click properties and then click cursor, i see all 4 coursors present. if i then delet ny of them, then on the xy graph;s cursor legent appear 3 cursos (name positions etc).
pretty weird behavior in my opinion.
any ideas about what to do at this point.
(5,284 Views)
Check on following links, might be you will find something worth.
http://digital.ni.com/public.nsf/allkb/280875F12A53D4FD8625699E006F0BBA
http://zone.ni.com/reference/en-XX/help/371361D-01/lvprop/intensitygraph_cursor_list/
Also please post your code, if possible.
(5,264 Views)
first of all thanks for replaying to the post.
here are some .jpeg files to show the observation.
i also wrote on them to make it easier for you.
regards,
(5,237 Views)
Which version of LabVIEW are you using? A similar issue ("Graph cursor values on the cursor palette never update") has been reported in LabVIEW 2009 and it was fixed in later versions of LabVIEW.
Sev K.
Senior Systems R&D Engineer | Wireless | CLA
(5,212 Views)
it seems it is also present on labview 2011
(5,197 Views)
Could you post your code. I would like to verify this behavior and , based on the result, submit a corrective action request.
Sev K.
(5,180 Views)
