CVIXMLLoadDocument error, reloading the xml file doesn't work.
I'm using several XML files in my LabWindowsCVI and the this is the situation:
 - I'm doing LoadDocument and GetRootElement with a specific path, but when this path changes I want to DiscardDocument and do the LoadDocument and the GetRootElement again for the new xml path.
When I "reLoadDocument" I get an invalid xml error, but my XML file has no erros, in fact I reload the same xml file just to check and the first time it works and on the "reload" it doesn't.
Any clues on what is the problem?
I apreciate any help.
Daniel Coelho
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
(2,864 Views)
Your question should be posted to the CVI board.
(2,849 Views)
