CWGraph3D reduced pixel resolution
Hi!
Is possible on CWGraph3D changed pixel resolution? On attachment i send you actual graph and graph with reduced pixel resolution. Is possible to reach this efect with changed of some CW Graph3D properite?
(3,355 Views)
Hi, The only way to change programatically properties of the graph is by using Property Nodes. In order to find some more information regarding on changing the properties programaticaly you can access this link http://digital.ni.com/public.nsf/allkb/A0BB4D90012A8BB98625731E00759819 Can you please tell me why do you need to lower the resolution for the Graph? Thanks.
(3,318 Views)
THis thread contains a worse case 3d Graph example where I manipulate just about everything except the point size.
That example may help,
Ben
(3,314 Views)
