Cable connection
I am mounting an SC-2345 in an enclosure and need to connect it to a PCI6036E located in a PC which stands next to the enclosure. How do I make the connection while maintaining the enclosure integrity? I have not been able to find a male-male gender changer that I can mount on the side of the enclosure to connect two SH68-68-EP cables (one inside the enclosure, one outside the enclosure). Is there a male - female cable available from NI or from another vendor?
Steve
(2,970 Views)
National Instruments does not provide 68 pin male-female cables. However, we do provide components for custom cabling. What might work best for you is to purchase a couple of the male PCB connectors and mount these on either side of the enclosure and solder them together. Then you could connect your normal female cables to these. Below is a link to the products page for these connectors.
PCB connectors
(2,970 Views)
