Calcualte the period of my imput on a FPGA VI
If Anyone would be able to help me. I want to calculate the periode of my input, and for that I used the fonction "Tick Count" and apparently it's not the right choice
Any suggestions
Thank you in advance for your replies
My best regards
Nadia
Message 1 of 9
(3,432 Views)
I am guessing you are just getting an increasingly larger and larger number for your loop timer.  You can use the tick count function as long as you are holding the previous value in a shift register and finding the difference between the two.  The white paper below gives other examples for finding the loop time in an FPGA VI.
http://www.ni.com/example/30439/en/
Message 2 of 9
(3,419 Views)
But a loop time function give me the speed of my loop, and what I'm looking for is how to get the period of my input(my signal)
My best regards
Nadia
Message 3 of 9
(3,402 Views)
Accepted by topic author k.nadia
Try checking out the "PWM Measurement" example in the NI example finder (just use the search to find it). It should cover everything you're asking about here. Feel free to post back with any questions you have about it.
Also, here's a relevant old post: http://forums.ni.com/t5/LabVIEW/PWM-Rise-Fall-detection/m-p/2503918#M762735
Cheers!
TJ G
Message 4 of 9
(3,395 Views)
Thank you so much
My best regards
Nadia
Message 5 of 9
(3,358 Views)
T-REX$  in your opinion, the sum of the high and low period will give me the period
Thank you advance for your answer
My best regards
Nadia
Message 6 of 9
(3,339 Views)
Yes, the amount of time high plus the amount of time low will give you one period.
Cheers!
TJ G
Message 7 of 9
(3,335 Views)
Hi T-REX$
Your method is working great
I still have a question. Do you see how to verify that my signal is not turn off
My best regards
Message 8 of 9
(3,215 Views)
k.nadia wrote:  I still have a question. Do you see how to verify that my signal is not turn off
You will typically want to have a max value for the period.  If your count for the period goes above that value, consider the signal to be turned off.
GCentral
Message 9 of 9
(3,197 Views)
