Calculate RMS with offset
I acquire a sinusodial waveform signal and calculate the RMS value using "Average DC-RMS.vi". The calculation works, if the waveform is symmetric around 0. If I add an offset, the calculation is wrong. Any ideas how to solve this?
Thanks a lot and best regards.
Michael
P.S.: I am using LabVIEW 2012.
Message 1 of 11
(15,352 Views)
Hi Micha,
What exactly is wrong with the result? Which result do you expect?
You know how the RMS is defined?
You might subtract the DC offset from your waveform before calculating the RMS…
Message 2 of 11
(15,336 Views)
Hello Gerd,
if amplitude is less high then the negative offset the vi calculates a positive value (e.g. amplitude 1V, offset -2V ==> RMS = 2,12V). Okay, depending on the definition, the result might be right, but in realitiy for me it is wrong. In reality it should be a negative value.
How can get the offset, if I only have a acquired wafevorm?
Michael
Message 3 of 11
(15,331 Views)
Hi Micha,
So you want to have a negative value - from an operation, which involves to square values and take the root from a sum?
Really???
No, even in reality the result is correct!
You need to define your requirements - and develop an algorithm to fulfill those requirements…
There are functions to calculate the DC offset from a waveform…
(Basically it's just the mean value.)
Message 4 of 11
(15,328 Views)
So, what is the task you have to solve?
I have a maybe similar task when I calibrate DAQ cards: My calibrator (Fluke 5700A :)) create a well defined RMS output and the DAQ will read a sine including an offset (and more) .  In my application the sine amplitude is the value of interest.
So I apply a sine fit ( easy method is tone detection.vi 🙂 ) to get the amplitude and phase and look at the residual (RMS :), peak to peak noise, offset and (harmonic) distortion).  Read a full number of periodes that also matches full periodes of your line frequency and you can get nice results.
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 11
(15,303 Views)
Suppose I generate a random signal (using the NI Random Number generator which gives values between 0 and 1) of 1000 points and ask "What is the offset of this signal"?  What would you answer?  How did you get that?  What if I added an (unknown-to-you) additional offset to it?  How would you compute the offset?
You could do the same thing with a sinusoidal signal, but you might be a little bit "off" depending on how you define "offset".  To understand what I mean, consider that the signal represents a half-sinusoid, i.e. sin (theta), where theta goes from 0 to pi.  If you have many cycles of a sinusoid, the "offset estimation" method I hope you figured out from the previous paragraph should give a more accurate answer.
Bob Schor
Message 6 of 11
(15,285 Views)
Us the;
Signal Processing >>> Waveform Measurments >>> Basic Averaged DC-RMS
to calculate the DC level and simply subtract that DC from your waveform PRIOR to getting the RMS value and you will get the value you want save the negative sign.
Spoiler
Somewhere in teh back of my head there is an alarm going off saying "Negative RMS? Doesn't that break some physical law if not qualify one for  a Nobel prize or something?
Ben
Message 7 of 11
(15,277 Views)
@Ben wrote:
Spoiler
Somewhere in teh back of my head there is an alarm going off saying "Negative RMS? Doesn't that break some physical law if not qualify one for  a Nobel prize or something.
It's perfectly logical if it's the RMS of an imaginary signal, the Imaginary RMS. 😄
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 11
(15,263 Views)
turn it 90° or 270° ??
Henrik
LV since v3.1
Message 9 of 11
(15,255 Views)
Accepted by topic author MichaGue_01
No.  RMS is a measurement of the AC component of a signal (closely related to peak-to-peak).  Offset is the DC component.  So RMS should never be negative.
As Ben stated, to do your measurements properly you need to calculate the average of the signal (gives you the offset), subtract that value from every data point and then calculate the RMS.  If you have really tight limits, you should also do some processing to make sure you have an integer number of cycles captured.
Message 10 of 11
(15,235 Views)
