Calculate RPM
Hi everyone!
I have a Analog Output (Hz) of Pump, and i need to Calculate his RPM - how do i do that in Labview?
(3,375 Views)
Hi Shimi,
Generic answer for your generic question: You measure the signal using a DAQ device. Then you analyze the signal and convert the analysis result into the desired RPM value using the specifications found in the datasheet of your sensor/pump…
For more detailed answers you need to provide more detailed information!
(3,362 Views)
Sorry, I am new here,  what kind of detail do you need to be more specific to help me...
(3,357 Views)
How do you get the analog output (Hz)? Where does the analog output (Hz) come from? Do you have a manual?
(3,349 Views)
@Shimi_A wrote:
Hi everyone!
Well you need to know what that output means before you can scale it to RPM.
For instance if is it 1Hz/Revolution then the frequency (Hz) is the RPM
If it's 10Hz/Revolution then it's the frequency divided by 10
=== Engineer Ambiguously ===
(3,297 Views)
