Calculate area of an anomalous object
i wanna to calculate the area of an anomalous object , not the bounding box , any idea?
Message 1 of 15
(4,593 Views)
In particle analysis you have "Perimeter" you can use this.
Message 2 of 15
(4,571 Views)
Post an image if you can
Message 3 of 15
(4,569 Views)
hi,
Wondering if the following link help you to solve your problem.
http://en.wikipedia.org/wiki/Polygon
Regards
Message 4 of 15
(4,559 Views)
post the image as above
Message 5 of 15
(4,538 Views)
Since the picture is black and white, "white pixels/total pixels X picture area" would give you the area of the white objects. You could try the Read BMP.vi (or read jpeg, png) and the Unflatten Pixmap VI to get the 1-bit pixmap which is a 2d array of boolean. Maybe this could work.
Ben
Message 6 of 15
(4,525 Views)
Image to array and then count the number of nonzero array elements...that might work.
Hummer1
(if you have a conversion between pixel size and physical size you could then do the math...)
Message 7 of 15
(4,498 Views)
i used to believe that the above method can only get the total area ,not the area of each object , am i right?
or first use particle analysis to get the bounding box , then count the nonzero pixels in the bounding ROI?
Message Edited by adobefree@gmail.com on 12-02-2009 08:26 PM
Message 8 of 15
(4,467 Views)
Hi adobe... (is this your real email address???),
which post are you referring to ("the above method")?
Anyway: what's wrong with counting the pixels of each color? Easiest and probably surely faster than to calc the area based on area border...
Message 9 of 15
(4,441 Views)
    Yes exactlly
    i was refer to the method that converting a image to a U8 array , then count the nozero pixels number
    it's ok , but i was wondering is there any direct measurement, since ni can get the bounding box, why not give the real
area directly?
Message 10 of 15
(4,433 Views)
