Calculate frequency of each pulse from encoder
I am trying to calculate the frequency from an encoder, but I want the frequency for each pulse, and not just the average frequency so that I am able to find the percent difference between the max and min values.  By creating a waveform from the array and the time between samples and using extract multi tone I am able to get 3 frequency values, but I need a larger sample size to have reliable data.
(2,637 Views)
Never mind figured it out. Just calculated the period for each pulse, and then used that for calculating the frequency.
(2,617 Views)
