Calculate maximum value of subarray while creating it using a case structure and shift registers
I'm very curious how you would create your solution -"reshape the torque array into a 2D array, one cycle per row and then autoindex, taking the subset max for each iteration."
Is there an example you could provide using the .csv file I posted?
Message 11 of 11
(373 Views)
