Calculate output value with Custom Scale
I have defined some custom scale in MAX.
I just want to calculate the output value of an input value applied with these scale.
Process is simple :
X =>    Custom Scale  => Output Value
in            Process               out
Is there a way to do it simply (recall : custom scale can be linear, polygon, table etc ...) ?
(4,441 Views)
Hello Educhene1,
You can use easily with labview your scale created previously in Max.
You just have to drag your scale into a labview VI (diagram). Next to it, you can create a property node, select the "activescale" as a standart and create just below one intput in writing and one output (reading).
I'm adding you this link ( http://www.ni.com/example/26625/en/ ) which just describe what you are looking for, just in case.
Best regards.
P.Denis
(4,397 Views)
Well, in fact, now I have no scale defined in MAX.
I have a table with X and Y values like :
X                Y
1,0             2,0
2,0             4,0
5,0             6,0
and I want to know the Y value of the X value 3,0 for example (using this table scale).
Do you know how to do it simply ?
(4,300 Views)
Accepted by topic author educhene1
(4,270 Views)
