Calculating SNR of a signal being modulated by an optical chopper
Hello everyone,
I am inputing two signals from NI USB-9162, one channel inputs an optical chopper signal (Square wave) and another is the response signal from the sensor. I am looking for a response signal from the sensor with respect to the changing frequency of the optical chopper signal (figure attached). how can i exactly calculate the Noise Equivalent power of this sensor through signal to noise ratio at each modulating frequency ? There are many different ways to calculate NEP on internet but they are really confusing.
Thank you !
(1,829 Views)
You should probably be asking the engineer in charge of the project.  Unless that's you, of course.  What I'm saying is that usually whoever needs the data has ideas about how to obtain it and/or how to calculate it.
Bill
CLD
(Mid-Level minion.)
(1,820 Views)
I am looking for more ideas so that i could compare that which one is more efficient.
(1,816 Views)
Hi Yum,
When you already implemented an idea we can usually tell you about the effiency of your implementation…
(1,814 Views)
