Calculating Time from Given input.
Hi everyone,
I'm stuck at trying to calculate the time of a given waveform.
Given a scenario, i have a circuit that is fed to a DAQ card for processing in LabVIEW. The input data generates a squarewave form in LabVIEW. I'm using a general waveform function to view the squarewave. The input is generated from a sensor.It will continously give a pulse when it detect something. But when it a doesnt anything, there'll be no output. so, no waveform is reflected at the waveform function in LabVIEW.
When that happens, I want to find the time when there's no output reflected at the waveform.
regards, aisyah.
(2,720 Views)
If you know the period of your waveform, you could write code that detects when the input is 0 for a period of time that is slightly longer than the period of your waveform.
1.  Note time that waveform goes to zero.
2.  If waveform goes to 1 reset your timer.
3.  Loop and watch your timer, if the time minus noted time is greater than the waveform period, then write out the noted time.
(2,709 Views)
