Calculating cutoff-frequency, bandwidth, impedance from given x/y-array
i have two arrays representing the measured frequency and voltage data.
Is there in labview something already included to calculate these values:
1. cutoff-frequency
2. bandwidth
3. impedance
Thanks for help
(4,348 Views)
I don't think Labview has anything that does that, you'll have to make your own code.  The bandwidth and cutoff frequencies shouldn't be too bad.  Just scan the array and remove any values that are 3dB (0.707) below the max, or whatever your cutoff is, and then you can use the statistic VI and get the first value, last value, and range.
The impedance will be a whole different matter, not sure the best way to go about that.
Hope that helps
(4,329 Views)
I have now two x/y-values for each frequency.
x: 100 / y: 0.702
x: ??? / y: 0.707
x: 120 / y: 0.712
How can i calculate the needed x-value for y=0.707 which is between these two values?
(4,297 Views)
you need to do some interpolation 🙂
just hit Ctrl-Space to call Quick drop , enter interpol...   and you get a selection of possible ready made vis
Choose some of them, read the help  and use the one that fit your needs
Another way is the :
Threshold 1D Array Function
Owning Palette: Array Functions
Requires: Base Package
Interpolates points in a 1D array that represents a 2D non-descending graph. This function compares threshold y to the values in array of numbers or points starting at start index until it finds a pair of consecutive elements such that threshold y is greater than the value of the first element and less than or equal to the value of the second element.
If you cut an approriate portion of your data, this would work.
Greetings from Germany
Henrik
LV since v3.1
(4,280 Views)
Accepted by topic author OnlyOne
All of the vis only interpolate the y-value. But i neeeded the x-value for a given y.
Meanwhile i found the correct formula
X = ( (Y - Y1) * (X2 - X1) )  / (Y2 - Y1) ) + X1
(4,265 Views)
Where is the problem to swap X and Y ???
Henrik
LV since v3.1
(4,244 Views)
