Calculating the hart rate for realtime measurement with a Daq-card and heart beat sensor(LED)
I am having problem with calculating the hartrate for realtime measurement with a Daq-card and LED sensor. I am now using signal simulate to simulate the signal and de peak detector managed to count de peaks. But when calculating the heart beat it doesn't work. And now I am wondering if the way I am calculating the heart rate will work in realtime measurement with a Daq-card? This is my VI:
(2,902 Views)
Why did you start a new message thread?  Please continue in your original thread.
As you were asked there, why are you dividing an array by an empty array?  The result is an empty array!
(2,894 Views)
