Calculating time between two signals
Hi all,
I have OPC server and shared variables, which represent my inputs(0 or 1);
Let's say that I have only two inputs, what I want is to measure time between them, for example when first go to 1 and then after some time, second go to 0;
What is the easiest way to get this time in LabView?
thanks
_________________________
Rookie; LV 2011 on WIN 7
(3,617 Views)
If you right click on the shared variable, you can activate time stamp, so basicaly you can read the time when the last value was updated, you just compare and substract the values.
Kind regards,
Ion Rosca
(3,590 Views)
Did you manage to solve it??
(3,558 Views)
First, tnx for idea, I now use "sql query";  I don't know yet which one will be best for my problem, did you have experience with this "time stamp"?
thanks again 😉
(3,549 Views)
Yes, I've used it to see if the value was updated and was comparing using a shift register with the previous value. Try this, it is easy to implement.
(3,539 Views)
Here you have an example application that monitors timestamp, and performs logic based on the comparison.
Good luck, Piotr
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
(3,531 Views)
