Calculation of Time taking by VI-Not By Tick count I want other way of calculation
Hi Team,
I want to Calculate the time taken by VI.I am using tick Count but it is not the right way of doing.I want other way of doing it..
Regards
DS
(2,653 Views)
DS,
why is Tick Count not the "right way of doing" it? Are you talking about long times (>49 days)?
Norbert
Norbert
Expert: Geometry
(2,638 Views)
If the time is short (2^32 ms), tick count is the way to go.  If you are talking for longer times, you should use the Date/Time in Seconds.
For both of these, you need to take the time before you run the VI and right after and subtract the two times to get the amount of time the VI took.
(2,628 Views)
You could use this as well:
http://forums.ni.com/t5/LabVIEW/New-LV2010-VI-High-Resolution-Relative-Seconds/td-p/1213011
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,622 Views)
