Calculator Interface in Front Panel?
Hi There,
I'm wondering if its possible to have the Calculator Formula function found in the "Mathematics/Scripts and Formulas" Pallete in the block diagram be visible in the front panel?
I want to be able to select 2 different Shared Variables and use the Calculator fuction to come up with different formulas. Or is there any other method I can use to do this?
Storres211
(3,419 Views)
If you want create function of calculator , you can create by your own with lofics, which is basically a learning practice for LabVIEW developers at initial stage
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,380 Views)
