Calculator
I make calc and I have problem. I can only add if i mark "+" in constant string, if "x" only multiplay, you know what's wrong? Any idea what's wrong?
I use labview 2012
Kindest regards,
Mateusz
(3,471 Views)
Hi vudi,
- subVI: Don't create icons as you did with your subVI. Due to its transparancy its very hard to open by clicking on it! Use a closed border - it doesn't need to be rectangular…
- subVI: Calc your factorial like this:
- MainVI: Put all boolean terminals in their corresponding event case!
- MainVI: Please do some debugging on your event structure logic: what happens when you press "6", "-", "3", "=" (in this order)?
- Main/Sub: When you use strings in your main VI you should use a string (not a RING) input in your subVI!
(3,453 Views)
It looks like you are learning LabVIEW.  Here are a few links that provide some free training.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Here are a few more pointers.
  • Initialize shift registers unless you want to retain information between iterations (you don't in this case).
  • Avoid un-needed wire bends.
  • Don't display terminals as icons.
  • Don't wire a False to a while loop, you have no way of stopping your program exect by crashing it into a tree.  Add a proper stop button, or handle closing the program in the event structure in the "Panel Close?" event.
  • Ditto on what GerdW said.
(3,367 Views)
