04-21-2007 11:44 AM
04-23-2007
03:53 PM
- last edited on
08-19-2026
08:40 AM
by
Content Cleaner
Hello bmunden,
I am unfamilar with the MPX4015A sensor. I tried looking for a data sheet for this device and was unable to find any information on it when I did a Google search.
What does this device do? Does it measure pressure and then output a small voltage? Does this device measure sound pressure or physical load pressure?
DAQ assistant does have the something called the Virtual Channel Calibration.
Please give this a try and let me know if this resolved your issue. Else please clarify and I'd be glad to assist you.
Sandra T.
Applications Engineer | National Instruments
04-23-2007 04:15 PM
04-24-2007
09:53 PM
- last edited on
08-19-2026
08:41 AM
by
Content Cleaner
Hello bmunden,
Thanks for the additional information on the sensor. It looks like you would be using a voltage task to make the measurements. If you wanted to calibrate your device, you can run the Channel Calibration Wizard in Measurement and Automation Explorer (MAX). This tool allows you to quickly calibrate the entire measurement path for a channel – from the sensor through to the measurement device – and then apply the resulting correction to every measurement taken on that channel.
Please let me know if you have any additional questions.
Sandra T.
04-24-2007 10:32 PM
