Calibrating an array of grayscale pixel data
If I obtain an array from a grayscale picture which shows the grayscale pixel values from 0-255, how do I calibrate this onto another array so I can use the new data within an equation. For my project each value of grayscale is equivalent to a temperature. For example the value of intensity 20 is equivalent to 2380K, 40~1920K How can I do this. Please help!
(3,015 Views)
I'm sorry I didn't reply to your original thread, like I said.
If you have a 2d array of 8-bit values, make two for loops inside each
other. For each value, do the calibration operation you like to do. The
fastest way is to make a 1d array of values outside the two for loops, and
in the two for loops, look each gray scale value up in the 1d array.
If you are looking up the original values from the bitmap in the lookup
table of the bitmap, you could modify the original lookup table to reflect
the calibrated values. This will save processor time.
Hope it helps,
Wiebe.
"mepgkas" wrote in message
news:506500000008000000916D0000-1031838699000@exchange.ni.com...
> grayscale pixel val
(3,015 Views)
I have this program that was modified for me. I am not sure how I need to do what you say. Is mine from a look up table? Can you help from looking at the program?
(3,015 Views)
If the relationship between int8 pixel value and the temperature is
linear, you can do this pretty easily in the intensity graph.
The intensity graph takes a 2D array of numerics and maps them to colors
through the Z Scale. The Z Scale defaults to displaying the numbers as
is, but by using the Offset and Multiplier for the Z scale, you can give
a linear function to map the pixel values to
another numeric range.
Greg McKaskle
(3,015 Views)
