Calibration cert for USB-6008
It doesn't look like the USB-6008 is supported by the basic calibration certificate generator.   I need calibration certificates for several of these units to meet ISO 9001 requirements.  What do you recommend?
Treck
(2,974 Views)
You may want to post this in the Multifunction DAQ forum.
(2,963 Views)
The low cost USB DAQ solutions do not have self calibration.  They also do not have calibration certificates. If you do need calibration certificates with your devices then the PCI 6221, or USB 6215.
Michael D
Applications Engineering
(2,943 Views)
You should be able to have a local instrumentation calibration service calibrate this to NIST standards.
(2,934 Views)
My response did not post everything I typed.  Like Brian mentioned you could probably get a calibration center to calibrate the device and give you a certificate.  I also meant to say those devices would be good alternatives. So your choices would be to look for a calibration center that would do it for you, or to get a higher end DAQ device.   Sorry for the brief and unexplanatory post from before.
Have a great day,
Michael D
(2,925 Views)
