Calibre I2C programming
I am using LV 7.1 and want to alter the resistance on some Xicor Digi-Potentiometers, I have been given a Calibre I2C interface card to use which is supplied with some Win32 DLL's , has anybody any experience using this card or similar. I presume I can use call library function to use these DLL's to do what I want.
(3,384 Views)
It has been years....
Yes, I have worked with it.
Make sure your voltage level is set correctly (5 vs 3 V, they came in two flavors back then).
I just called the DLL's as you mentioned. I can not think of anything else I should warn you about.
Have fun!
Ben
(3,384 Views)
Hi
I agree that by calling the DLL the desired function could be achieved.
Best Regards
Atul Wahi
www.ni.com
(3,384 Views)
