Call Chain Error 7
I am using LV8.5 and have a project that I've been using consistently to build and exe file.  I then added some code to allow for command line arguments to be passed in, and I get the dreaded Error 7.  Here is the error text that I see, and attached is a png of the code I added.
LabVIEW cannot find a file that is a dependency of a Startup, Exported, or Always Included VI.
File Not Found: .
The missing file might be referenced by one of the libraries included in the build or by the file - TSCx.vi. To fix this issue:
- Open all Startup, Exported, or Always Included VIs, recompile them (CTRL+SHIFT Click the Run arrow) and save them to update their dependencies.
<Call Chain>Error 7 occurred at AB_Engine_HandleLinkErrors.vi -> AB_Engine_Update_Source_from_Linker.vi -> AB_Build.lvclass:CalculateDependencies.vi -> AB_Build.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Page_Preview.vi
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Nonexistent GPIB interface.
Message 1 of 11
(5,979 Views)
You have a VI reference you added for TSCx Main.  What is the path for this file?  Do you have it at the location where it is looking for it?
Message 2 of 11
(5,975 Views)
Just to be sure, I right-clicked on the reference and re-did the Browse For Path, and still receive the same error.
Message 3 of 11
(5,970 Views)
Is it possible the path to the file is too long, or on a completely different branch of the file hierarchy?
Search for error 7 and build.  This error has come up numerous times before due to one of a few reasons.  Perhaps this thread will help.  http://forums.ni.com/t5/LabVIEW/Error-7-during-the-build-LV-8-6/m-p/1670728/highlight/true#M595880
Message 4 of 11
(5,967 Views)
That link that was referenced had a couple of ideas.  I tried the file path length issue by pointing to a file right at the root of my d-drive (d:\InstrHandle.vi).  It's not the same file as original, but I was just trying to rule out the path length.  It still complained.  In fact, the original path with filename was only 50ch.  I also tried a mass compile.  No luck.  It's just bizzare to me that if I remove that block of code, the build works fine.
Message 5 of 11
(5,956 Views)
I started adding little pieces at a time (from the original block).  The build process was successful until I got to the Static VI Reference.  I didn't even have the Invoke Node added yet.  Just the Static VI reference (I put it inside a true/false case statement), and the build bombs.
Message 6 of 11
(5,954 Views)
I didn't think to ask this question because I think I did a very similar thing in another application .... Anyway, can the static VI reference reference the same VI where the static reference resides?  I'm thinking the answer is no.  Once I pointed to a different VI (in another folder), I was able to successfully build.  However, I'm trying to pass in a number of command line parameters and kick off this VI (i.e. its front panel title, minimize, etc).  How else would I do this?
Message 7 of 11
(5,952 Views)
When I changed the Static VI Reference to a VI Server Reference, the build was successful, though I'm not entirely sure why
Message 8 of 11
(5,951 Views)
Are you saying that the reference was to the VI it was inside of?
Message 9 of 11
(5,947 Views)
yes.
Message 10 of 11
(5,938 Views)
