Call Dll failed when i build the program to application
hello, i have a trouble that build the program to application, my VI include 'call library function node', the VI works fine, but when i build it to EXE,  it will be error like the picture.
(2,798 Views)
No Attachments Found, Also check if the path for the dll is changing, since Application takes different path directory.
Also Make sure you are adding your Library Files/DLL's in always included while building application
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,785 Views)
If you are specifying the path of the dll on the block diagram, make sure that the path is not changing after building the executable. Otherwise if you have directly selected the dll using the configure window for CallLibrary node, make sure you include the dll in your project window and include the dll within the 'always included' items section in the exe build settings.
Waiting For the inner calling 🙂
(2,782 Views)
hi Palanivel Thiruvenkadam,
Sorry, i had attached the picture, but i don't know why it cannot found.
In my program, i used a third party DLL, the DLL will be placed in a fixed location when i install software by default, you can see the DLL path.png. In subVI, i call the DLL by 'call library function node' and set the DLL path, you can see the config in call library function node config.png. I add the DLL to always include as your side, the error remain, you can see the attachment, thanks for your help.
(2,742 Views)
hi
In my program, i used a third party DLL, the DLL will be placed in a fixed location when i install software by default, you can see the DLL path.jpg. In subVI, i call the DLL by 'call library function node' and set the DLL path, you can see the config in call library function node config.jpg. I add the DLL to always include as your side, the error remain, you can see the attachment, thanks for your help.
(2,740 Views)
