Call Library Function Node not Supported
Hai,
I have question to ask to NI members. I get an error said " Call Library Function Node 'LVASPT_WA.*:SptDecimationFilterH':Node not supported". I use the call library function node in the FPGA.VI in my design. My question is, is it the function cannot used in FPGA.VI? I try to search a similar thread and find the manual but still can't find the answer. Anyone please clarify it to me. Thanks in advance.
(3,828 Views)
You cannot use Call Library Function Node in FPGA. The FPGA is hardware - it has no way to call an external library. If it is not immediately obvious why it's impossible for the FPGA to call a DLL, you should spend some time understanding what a FPGA is.
You can integrate FPGA code written outside the LabVIEW environment, but that's not the same as calling a DLL.
(3,821 Views)
Hai nathand,
Thanks for your clarification. Actually I try to write a decimation filter operation in FPGA.VI by calling the library function. Since I can't use the function, I will try to rewrite the filter operation without using the function maybe. If you have any idea or suggestion, I very appreciate it. Thanks in advance
(3,814 Views)
