Call Library dynamic path problem
Hy all,
i use Labview 8.5 anf  try to  call one of my lib (develop with labview too)
When I filled in the configure panel of the call library with the path of my lib and don't check the specify path everything working good.
but when I try to use a dinamic path (I leave the Library name or path empty, keep the Function name,check specify path on diagram and link the path of my library to the path connection of the  call library vi) then Labview freeze. I must  kill it :smileymad:( because it stay block on reseting vi) and restart it  .
Anyone can help me please?:smileysad:
thanks
(3,172 Views)
Could you please post a screenshot of this for our better understanding.
Mathan
(3,168 Views)
Hy again, here is the sreenshoot of the configure windows of the cal lib and the call to the function too for the working case and the non-working case.
Of course in the non-working case i have chack that the path to the lib is correc.
thanks
(3,161 Views)
