Call Library to generate user event with complex cluster.
What is the best way to have a dll generate a user event where the data type of the user event is a cluster that contains a double, an array of U8 and a string? I tried to pass the event parameter to the dll with the Type set to "Adapt to type" and the Data Format set to "Handles by Value". However this gives me the "Not enough memory to complete this operation dialog." and an error 1097.
Kind Regards,
Stefan
Message 1 of 1
(3,110 Views)
