Call Simulink dll without using real time target
Hello Everyone,
I would like to know if anyone has converted a simulink model into a dll using the SIT(simulation interface toolkit)
and then called the .dll from a LabView vi WITHOUT running the dll on a real-time target i.e. just your PC. ?
I'm not concerned about real-time operation on a hardware, all I want to do is to call a .dll built from simulink and
have it be controlled by a Labview front panel. Unfortuneately, there is few example available shipped with LabVIEW, so
could someone give me some tips or examples for this topic.
Any help would be greatly appreciated!
Have a wonderful day.
帖子被xyl4804在 05-15-2010 04:06 AM
时编辑过了
(3,912 Views)
Posted here as well: http://lavag.org/topic/10254-simulink-interface-with-labview-without-real-time-target/
Message Edited by rolfk on 05-16-2010 10:42 AM
Rolf Kalbermatter  My Blog
(3,883 Views)
waiting, for solution...
(3,855 Views)
Hi, it's easy for us to import simulink model into LabVIEW with SIT, just for simulation, but not running with hardware. Also, you can refer to example, such as 'batch simulation.vi' to implement this on PC after installing SIT, just for simulation!! So, I don't konw the reason why you plan to call dll in LabVIEW, but not make use of SIT directly? NI Application Engineer Ben
(3,749 Views)
